Xigmatek S1283 or Sunbeam Core Contact Freezer
1585 Views 17 Replies 13 Participants Last post by  nirianto
Hey Guys,
I have to choose one between the two to cool my 9850BE in CM690. Which one would you choose? and why?
The only major difference between the two: Xiggy can only blow out to the top exhaust while the SCCF can blow out to the rear exhaust. I have 2x120mm fan at the top exhaust and 1x120mm fan at the rear exhaust.
Cheers.
1 - 18 of 18 Posts
HDT-S1283 for sure. Get a Xigmatek Crossbow with it though. The Core Contact Freezer has a horrible mount which doesn't provide much pressure at all and can't be replaced.
i say the s1283 because, it give better temps. but that IMO. CCF is also good but i haven't seen any reviews for it yet. (I know there reviews online but i dont have time to search it >__<)
I have installed S1283 before and it was a breeze. No cuts no bloods. I am expecting that installing the SCCF will be difficult just cuz the of the way tight spacing between the fins and the latch.
Based on its orientation, S1283 could potentially blocked the first ram slot if you have ram with raised heatsink. The SCCF will not fit if you have a tall NB cooler.
Did you just answer your own thread?
Xiggy is great, just get some AS5 or MX-2 thermal paste. I have the Xiggy blowing out the back of my case, is it just that your case is to short? Either way, top or back, it should work equally well.
The CCF has a horrible mounting system, you'll spend atleast 2 hours trying to put it on your motherboard without snapping it in half. I had to bend my motherboard roughly 40 degrees before the heatsink would lock into place. It's extremely hard to remove the heatsink as well. I would just go with the s1283.
Thanks! I figured the s1283 has a much better mounting system than the CCF. I'll go with the s1283 then! Thanks guys!
I had absolutely no problems mounting my CCF. It is a bit of a pain to take it off for reseating, but that entire process only took me 25 minutes....and that include the removal of the motherboard.
its only an issue with Intel CPU's with AMD its fine.
I've had both and I like my CCF better. I've never had any problems with the mounting, It takes less than a minute to mount on AM2 and even less to take off. Also allowed me to take my 940BE to 4Ghz.
Get the Sunbeam, a friend has it, and its ubber HSF, will let you OC very nicely,, gl,
Xigmatek HDT-s1284ee.
4 8mm heatpipes that are spaced 1mm apart and even more heat dissipating aluminum fins.
Hmm okay...i guess i could try the CCF on 9850BE...my load temp on 9850be is 65C...thats running at 1.5v and 200x16...its a bit too hot i think!
Make sure you get a good TIM too! IC Diamond is right up there with the big boys, and I think it's just as good/slightly better than others.
The CCF comes with a full tube of TX-2 which is a good TIM
So, I just replaced the S1283 with CCF and to my surprise, it drops idle temp by 3C to 25C!! I'll check the load temp later.
1 - 18 of 18 Posts
