1 - 9 of 9 Posts
Super Moderator
http://www.xfastest.com/viewthread.p...ge=1#pid149879
Not news, so I'm putting it here. There's a reason I keep that site bookmarked even though I can't read Chinese, and that's part of the reason. To save you the trouble of running it through a translator yourself and decrypting whatever comes out (and in fact going over the images), I already did that myself. Though the link is more there for you to look at the screenshots yourself, since they use some funky zoom script that's making it hard for me to find the links to the full-res images without going CTRL+U and searching through everything. Too lazy to do that.
Anyway! This is how it went, in my own words.
Red is the Hammer. Blue is the TRUE Black.
The first test is using the Hammer on a Core i7 920 on the DFI DK X58 T3EH6 at 200x13, 1.1v VCore, running Hyper PI 32M at X8.
Result in RealTemp is
47 47 44 44
48 48 51 51
The second test is after Hyper PI completes, with VCore dropped to 1.08.
33 33 28 28
62 62 67 67
Third and fourth tests are under identical conditions, only using the TRUE Black.
Respective results are
46 46 42 42
49 49 53 53
and
35 35 31 31
60 60 64 64
Fifth test is using the Hammer, 200x19, 1.37v, same test conditions otherwise.
67 67 66 66
28 28 29 29
Sixth test is after Hyper PI completes, and VCore is dropped to 1.34v.
37 37 32 32
58 58 63 63
Seventh and eight tests are under identical conditions, again using the TRUE Black instead.
Respective results in RealTemp are
66 66 65 65
29 29 30 30
and
40 40 36 36
55 55 59 59
Thoughts? It's pretty promising if you ask me.
Before anyone asks, there was no mention of what fan the guy used, only that there's equal push-pull potential between the 2 of them (obviously).
Super Moderator
Originally Posted by Adrienspawn View Post
I had a hard time understanding which numbers were which, so I clicked on the source and now my head hurts.
Yeah, I'll see what I can do about that.
Edit; Aghh, forget it. Just read it really carefully and it should be... at least a little comprehensible.
so..how exactly was the test result...I really couldn't figure it out what those numbers means.....
looks like ADDA 2500rpm fan...what fan is that?
edited....sorry question, what is the temp for both under overclocked and loaded?
Super Moderator
Discussion Starter · #6 ·
Like I said, just read through really carefully and it'll make sense. It might just be me not thinking straight but I honestly can't figure out a way to make it clearer than that. Not once did I see mention of what fan was used so your guess is as good as mine.
after translating it (foreign exchange student's do come in handy some times
) it turned out to be an ok review
I don't get it, which one did better???
Super Moderator
Discussion Starter · #9 ·
I had an idea, and it didn't hurt. Color coding the results by cooler. Compare the first red result with the first blue result, second with second, etc. for clarity. To me, the TRUE did better at higher voltages before Hyper PI completes, and the Hammer did better at lower voltages after Hyper PI completes.
1 - 9 of 9 Posts
