Originally Posted by ap10016 Hello, Anyone have any experience installing an xp120 onto an a8v deluxe mobo? I've read some things about the size of the cooler being an issue, not specifically for this board, but in general. Thanks, -Andrew |
Originally Posted by andy_s_1 ive just got this mobo and HS, should have it set up by the weekend, ill let you know how it goes! ![]() |
Originally Posted by cgd Installed one lastnight on an asus a8v. Even though it fits fine, getting the top-back clip latched is near impossible. It's a whole lot easier to remove the mb. Takes less time too. The problem is, when you plug in that four-pronged power cable, you have to do it thru the rear fan vent. The fan guard on my case was a part of the case so I ended up cutting it out. The only way the hs fits is with the curves in the pipes towards the front of the case otherwise, they hit the capacitors. |
