XP-x64Pro very slow boot... any ideas why?
264 Views 6 Replies 3 Participants Last post by  Russkiy
Hey guys, I installed 64bit XP on my friend's machine (not in the sig), and it takes like 70 seconds to boot. It's a clean install...
Velociraptor 300GB
E6600 @ 3.5ghz
4gb Patriot PC8500elk
gtx260 core216
Please tell me how to resolve this problem. And what can I disable to make it boot faster?
1 - 7 of 7 Posts
So this is from power on to login screen or all the way to the desktop?
I would just double check what programs might be running in startup first.
You know how that progress bar on theboot screen usually takes under 10 cycles?
Mine does nearly 30 before it disappears...
Originally Posted by TnB= Gir View Post
Is it updated to SP2?
Yes sir!!! got the latest updates for everything
BUMP, any ideas guys?
BUMP... need help ASAP
1 - 7 of 7 Posts
