1 - 2 of 2 Posts
Hello, all. I have a question on mounting this CPU block on my mobo. I'm mounting it on an ASUS M3A79-t board, I took off the mobo's backplate to use the universal mounts provide by XSPC. My question to anyone is how tight should I screw down each "spring screw" on each side of my universal mount?
Any help is appreciated... I bought this CPU block new but never received any Mfg instructions.
Thanks
IF you have a backplate tighten it asmuch as you can with your hands and feel that the block cant twist left or right..If you dont have a backplate tighten is until your board starts to flex and then loosen it just a little.
1 - 2 of 2 Posts
