1 - 3 of 3 Posts
I need a couple of narrow 120mm rads for a build... there is very little room to play with in the case and it seems the only rads that will fit (I think) are the XSPC EX120 and the EK-COOLSTREAM SE 120... both are just on 12cm wide. From my measurements, I don't have much more room than that, a few mm at most. All other rads seem 13cm+ which is too wide.
From what I've read, the EK SE 120 isn't a great performer and requires high fan speeds due to its high FPI. XSPC seems better in this regard, and I've used their rads before with decent success, just not this model.
Any advice much appreciated. :)
1 - 3 of 3 Posts
