1 - 7 of 7 Posts
RX360 kit
Then go amazon and buy the 10 feet of primochill tubing.
Or use the 50 bucks to buy Gentle Typhoon fans. World of difference. But u can also buy yate loon fans if you want to go cheap.
Originally Posted by Kick
RX360 kit
Thanks! Question....What's the difference between RS and RX?
RX is a thicker radiator, roughly twice as thick, and it also cools better. I went with the RS 240 because I didn't have the space to mount it internally, but if you do or if you're mounting externally then definitely go with the RX.
Thanks!
I don't think I"ll have the space to mount internally either...is there an easy way to mount externally?
1 - 7 of 7 Posts
