1 - 5 of 5 Posts
looking someone whos more intelligent then i (shouldn't be hard..lol) to answer a question for me . i have the XSPC Raystorm 750 RX360 kit installed on my computer. i have 3 GTX 680 superclocked signature 2 cards and a AMD FX-8350 overclocked to 4.8 and noticing the idle temps are 34-35c on cards and idle on the CPU are 24-25c , i was wondering if i needed to add another rad to compensate for the cards or what? i have a buddy whos air cooled processor(which is the same as mine) is getting better temps then mine! also wondering if the pump/res will be able to push if i decide to add the extra rad. any help greatly appreciated
More rad would definitely help. General rule of thumb is 120mm per block in the loop, plus 120 for headroom. You have 4 blocks, so that's 480 right there. With headroom, 600.
I don't know what case you're using, but if you can fit a 240mm rad, or even another 360, your temps should improve markedly.
Reactions: firefighter6252
If you have revision 4 of the pump, you're probably ok. Anything earlier and I'd consider getting something better.
1 - 5 of 5 Posts
