News straight from the Swiftech CEO. Not even on the Swiftech website yet.
MSRP: $179.95. Source is in my last comment.
Source
I am proud to announce the upcoming release of the Epsilon full-cover water-block for nVidia GeForce GTX295 (P658 reference model, currently described as "the single board version"). Here are some sneak-pics: ![]() The block ![]() Pre-applied thermal pads ![]() Re-use of the stock back-plate ![]() Installed on the card ![]() In operations My sample EVGA card oc'd to 741-1602-1260 with this block. I just wish there was a volt mod available Here are some excerpts from the [unpublished yet] product page: The Epsilon™ water-block offers superior thermal performance at the GPU level thanks to an embedded thin-pin matrix located directly above the GPU area. Flow restriction is moderate by design in order to take into account multiple water-blocks in the same loop. The base plate is made of chrome plated electrolytic copper, as opposed to commonly used nickel plating which is yellowish, and the top is machined in clear polycarbonate material. The advantage of polycarbonate over widely used acrylic is that it is virtually impervious to cracking. Shipping to retail channels will begin next week. Price will be in line with competitors offerings. Note: Unfortunately, I will be unavailable for comments over the week-end as I will be travelling. |
Source
