http://www.fantronic.com/yate-loon-1...peed-p-80.html
Specifications * Model: D12SH-12 * Dimensions: 120x120x25mm * Bearing: Sleeve Bearing * Power connection: 3pin motherboard power connector, and 4pin molex (psu power connection) has both connectors, you chose which one you want to use. * Rated Voltage: 12 Volts * Operation Voltage: 6.5~13.8 Volts * Input current: 0.30 Amp Max * Operation temperature: -10 to +65 C * Storage temperature: -40 to +70 C * RPM: 2200 +/- 10% * CFM: 88 * dB: 40 * Corners Closed |
