Same exact concept if you wire them all to one molex (they're still in series = same voltage/amperage draw = no difference from daisy chaining)
As for the fan controller, it depends on how much Wattage the individual channels of the controller are rated for (since the power equation tells us that Wattage = Voltage x Amperage)
To apply that, let's take the sunbeam rheobus as an example...
It can handle 20W per channel
Voltage x Amperage = Wattage draw
12v x .30A per fan = 3.6W per fan
3.6W per fan x 6fans = 21.6W total draw
6 fans would draw 21.6W which would be 1.6W too much for a single channel on the rheobus
PM or post back if you want clarification or more help
