Status
Not open for further replies.
1 - 12 of 12 Posts
I have never built a computer before.
Sure i have upgraded parts, installed fans and such, but never taken all the parts and put them together.
at the moment i am installing widows XP pro. when it finishes it will be ready.
how much do you guys think this computer can go for?
AMD Athlon 64 3200 Single-core
1GB DDR 333MHz RAM
60GB HDD + 200GB HDD (260 total)
ATI Radeon X800XT
480w PSU
ATI Enthusiast case (I am an nVidia guy but I have no bias)
CD/DVD Burner
2 120mm cooler master green LED fans..
sorry if this isnt the right place to post this. i just couldnt find a better place.
it can go for about 10-20 bucks tops
BTW gratz on your first build
You can probably get $100 - $150 on Craigslist. More if you find a good buyer.
I always recommend starting with a higher price, you can always go lower.
yeah, its not a great system at all, i know that. but its a project build. it was really really cheap to build (120 bux tops) including a new really nice heat sink.
my other computer (my specs) is better, but this was fun and skill building. now i know i know how to put one together for sure. so i am good
Yep, always practice on the cheap ones so u know what your doing when u get to the $300+ parts lol
Discussion Starter · #9 ·
the specs are listed in the top. i wll post pictures later. i think.
its up and running now. its running perfectly with the two big fans too.
I am going to go set it up with my stereo to test out the sound. this is pretty exciting even though the computer it self isnt very great.
Jayce
Originally Posted by Darqside;13077364
anyone tink it couls sell for like 250-300 dollars?
If the person has absolutely no idea what a computer is, yes.
If they have a single iota of intelligence, then absolutely not.
Also, you'd be better served taking this into the Appraisals section...good luck and grats on the build!
Discussion Starter · #11 ·
yeah, i read the post. but i think it can sell for more. i will aim for 300. i know this sounds bad, but not everyone is good with computers and know the prices. this computer looks pretty flashy and expensive. i think i can get 300 bux out of it.
Sorry, our forum requires the use of the Appraisals section for this topic.
1 - 12 of 12 Posts
Status
