Well, get some details on your OCing up ASAP
Originally Posted by Rukkee 255x11 will get you 2805 . @ that speed i didnt have to add much vcore to mine 1.425 was all. Use a 4x HTT 4X250=1000 . I did have to raise my ram volts thou , but your mem is better than mine . The lower the ram timming the better , but the higher speeds will make up for any of the looser timings . Id prolly try 3.4.4.8 2t @250 and test from there . Im sure you will be able to tighten them up after you do some prime runs. If you want to run lower timmings 2.3.3.6 1T you can run divider . The 333 divider should put you memory down to around 208mhz . Good luck! |
Originally Posted by Zipnogg Ncie system. I really like your avatar, btw. |
Originally Posted by The Duke Some good reading for you http://www.overclock.net/faqs/38169-...roduction.html |
Originally Posted by Sporadic E Glad it was not your Asus after all. See and you wanted to ditch and run to DFI. Got my new Asus installed today...lot's of new tweaks to play with. Good luck with the OC and you will really like that SD. Es |
Originally Posted by Edge When I start OC'ing and it wont boot because it didn't like my settings, is there a way to reset the bios without opening it up and doing it manually? |
Originally Posted by Sporadic E you dont need to clear it just enter the bios with the del and change what ever caused the no boot and try again. Es |
Originally Posted by foxracing4500 dude good choice on the 3700+ I got mine up to 2.9Ghz and its runing that daily! anyways check out the last page on that link in my sig. Most of this stuff can help you maybe or give you idea's |
Originally Posted by Rukkee 255x11 will get you 2805 . @ that speed i didnt have to add much vcore to mine 1.425 was all. Use a 4x HTT 4X255=1020 . I did have to raise my ram volts thou , but your mem is better than mine . The lower the ram timming the better , but the higher speeds will make up for any of the looser timings . Id prolly try 3.4.4.8 2t @250 and test from there . Im sure you will be able to tighten them up after you do some prime runs. If you want to run lower timmings 2.3.3.6 1T you can run divider . The 333 divider should put you memory down to around 208mhz . Good luck! |
