Looking to order my loop, and want to run a few things by the WC guru's. I did not list a kill coil, distilled water, fittings, etc.
Here is a list of what I'm looking at
x2 XSPC RX 360 rads
x1 Swiftech 35x
x2 EK 5870 water blocks
400mm res
x1 EK Supreme HF
x1 undecided CPU water block
Now for the questions:
For my 2nd CPU block, I'm torn on spending the extra 40$ or so for a 2nd supreme HF or if I should go with the "Light" version for half the price of the supreme. It will be cooling an underclocked NAS system so won't be putting out a ton of heat . . . but will it adversly effect the overall flow of the loop?
Will a single 35x handle all of that? I asked in here once before and got a single reply - but I'm not sure if one pump is enough. It's hard justifying the expense of a 2nd pump and top, but with approaching $1k for the loop, what's another couple hundred . . .
Thoughts?
x2 XSPC RX 360 rads
x1 Swiftech 35x
400mm res
x1 EK Supreme HF
Thoughts?
