1 - 20 of 31 Posts
These are proposed specs for my pc. The machine will be used for running Windows XP and gaming, it needs to run Vista as well. My budget is around £800 ($1500) and I would like the pc to last me for a fair bit. Any help will be greatly appreciated!<br />
<br />
CPU: Core 2 Duo E6300<br />
Motherobard: Asus P5B Deluxe<br />
RAM: G.SKILL F2-6400PHU2-2GBHZ<br />
Graphics: Sapphire ATI Radeon X1900 XT<br />
CPU Cooling: Arctic Cooling Freezer 7 Pro<br />
Case: Lian Li PC-7B PLUS<br />
PSU: Hiper 530W Black Type-R Modular<br />
<br />
If you can recommend any better parts i am open to suggestions.<br />
Cheers! <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
You might want to get faster ram because of the low multi on the 6300. <br />
<br />
Either that or upgrade to a 6400.<br />
<br />
Looking good otherwise.
Replace the Hiper PSU with something that would provide more amps on the 12v rail<br />
<br />
Can you link me to the site you're ordering from?
Discussion Starter #4
PSU: <a href="http://www.ebuyer.com/UK/product/112897" target="_blank">http://www.ebuyer.com/UK/product/112897</a>
If you plan on overclocking the beasts of Intel, the P5B-E seems to be the current OC'ers choice. Depending on what attributes (bells and whistles) you want on the MB, you may fair better with your current choice in MB's. Personally, I will obtain an E6600, P5B-E, OCZ PC6400 (due to systems built personally that I know these mate well with the P965 chipset), graphics card has YTD due to 1)Speed Matters, 2)HD doesn't, suggestions on card greatly appreciated. Was looking at EVGA 7900GTO, can't seem to find it anymore.
I guess that Hiper is the best available at that price point :/<br />
<br />
The prices over there are insane x.x
Discussion Starter #7
Will that PSU be sufficient though?<br />
Could i get any better graphics for the same price as Sapphire ATI Radeon X1900 XT?
I remember one member here from the UK stating that the 7900GTO was £20 cheaper than the x1900xt? Might want to look into that<br />
<br />
The PSU might not be enough, I'm not sure how many watts the x1900xt consumes<br />
<br />
Maybe someone from the UK can help out?
Discussion Starter #9
Okay, well thanks for your help.
Don't look for the rated wattage. Look for amps on the 12v rail. That PSU will handle the 1900 just fine.<br />
<br />
Have you searched any other websites for better deals?
Discussion Starter #11
I'll look now
i suggest :<br />
<br />
<a href="http://www.overclockers.co.uk" target="_blank">www.overclockers.co.uk</a><br />
<a href="http://www.scan.co.uk" target="_blank">www.scan.co.uk</a><br />
<a href="http://www.komplett.co.uk" target="_blank">www.komplett.co.uk</a><br />
<a href="http://www.aria.co.uk" target="_blank">www.aria.co.uk</a>
P5BDX > P5B-E in every way except price (duh)<br />
<br />
I'd go with that if you can afford it. Apparently it can make a pretty big difference
Discussion Starter #14
<a href="http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=154679" target="_blank">http://www.scan.co.uk/Products/Produ...oductID=154679</a><br />
That's a 460W PSU (should be enough). It only says there are dual 12v rails.<br />
I'm stuck <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
Discussion Starter #16
£60 ($115) M.a.x
<a href="http://www.overclockers.co.uk/acatalog/Online_Catalogue_This_Week_Only_25.html" target="_blank">http://www.overclockers.co.uk/acatal...k_Only_25.html</a><br />
<br />
The 500w Corsair is at "£76.36 Including VAT"
Discussion Starter #18
Okay, that looks promising ill most likely get that <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> . <br />
Just got to get graphics sorted now......
Discussion Starter #20
I can get it for £170. ($340)<br />
My budget's is probably no higher than £180 though...<br />
nVidia or ATi...
1 - 20 of 31 Posts
