1 - 6 of 6 Posts
so you lose warranty if you sleeve your PSU right?
since i asked Coolermaster and this is the answer :
Dear Ms/Mr,
Thank you for your inquiry.
Sorry for the late reply.
Sorry to tell you that you don't have warranty anymore when you change the product from it's original state.
Check also our:
Spare part shop: Refurbished Cases, Coolers, PSU: [URL=http://www.coolermaster.nl/shop/]http://www.coolermaster.nl/shop/[/URL]
PSU Calculator: [URL=http://www.coolermaster.outervision.com/advance.jsp]http://www.coolermaster.outervision.com/advance.jsp[/URL]
Kind regards,
Technical support
Coolermaster Europe
From: [URL=mailto:[email protected]][email protected][/URL] [mailto:[email protected]] On Behalf Of Lan Hu
Sent: Tuesday, September 07, 2010 11:12 PM
To: [URL=mailto:[email protected]][email protected][/URL]
Subject: Sleeving a PSU
I believe you lose the warranty when you break the your warranty is void if you break this seal sticker
yes if you break the sticker
You void the warranty if you tamper with it in any noticeable way.
So, if you visually change it, by sleeving it; this requires opening up the PSU and therefor breaking the sticker on the inside, it will void your warranty.
Discussion Starter #6
sleeving does not tamper with the unit itself but only the cables :/
you put a nice new cloth over the original one.
1 - 6 of 6 Posts
