Please i need your advice, the best option (where/how) to add my new Xspc RX360 Rad, to my currant lop. I am planning to fix the Rad top of my case. ((Please check picture # 1))
I would just replace one of the 120mm radiators with the new radiator. Those 120 radiator probably aren't doing much anyways, so you can just disconnect the hoses from the old 120mm radiator and connect them to your new 360.
Sound very good,
But don't you think if i use both the 360 + 120 my lop will perform better than the 360 alone?
Yes, but the performance difference will be so minimal (<2C) that I don't think it's worth the hassle of trying to reconfigure your tubing.
Yes you are totally 100% talking the right and helpful thing..
Thank you very much for your great help and answers..
1 - 7 of 7 Posts
