1 - 6 of 6 Posts
i just picked up some z-2300's for a very cheap price
but my only issue, is that if the volume nob gets knocked, just a few cm, the volume goes super load and all hell breaks loose!!!
is there some kind of volume limiter!!?
VeeDub Enthusiast
i usually just control all my volumes right in windows, as i had a similar issue with some speakers before
(takes a couple of days to get used to, but works like a charm mate)
Man with Fans
Case in point: my MX5021's.
These have a digital control. But all hell breaks loose when kids decide to play with the remote that comes with it. The volume ramps up faster than Gordon Ramsey can curse.
Thats pretty fast.
I tend to just use the nob :/
***** That was good. Made my day.
to op, I would just set it at a volume you like and move it to somewhere where it wouldn't get knocked. I say behind the monitor or such.
1 - 6 of 6 Posts
