1 - 3 of 3 Posts
From what I can tell it looks like the BIOS was gutted by EVGA.
They state to select Selectable Graphics to run multi monitors but the option has been ripped out. BIOS update notes state that XMP support had been improved but it basically doesnt support XMP profiles at all that I can find.
I really needed to run an older VGA monitor but this 290x doesnt support analogue signals, the motherboard does, but not with a GPU installed.
Needless to say Im pretty fed up with this motherboard. Do you guys have any ideas for me to try? I wont be buying anymore adapters so if its a no go, then ill just have to consider this a lesson learned.
I dont think there is anything, but thought I would ask...
Ultra wide wide wide.....
EVGA make great graphics cards and power supplies.
They also make horrible motherboards
Yeah I thought it would be issues with overclocks and such but overclocking the cpu is dandy.
It's everything else that feels like a bad hangover.
1 - 3 of 3 Posts
