Yea usb3 controller is enabled so is usb3 legacy support.....
I have the asmedia installed -- idk if it uses intel or asmedia
wrong moboOriginally Posted by Master__Shake
go to the intel webiste and download the newest drivers for your chipset.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Software+Products&ProductLine=Chipset+Software&ProductProduct=Intel%C2%AE+Chipset+Software+Installation+Utility
then go to asrock's site and get the latest driver for the other usb controller
http://www.asrock.com/mb/Intel/Z77%20Pro4/index.asp?cat=Download&os=&c=
then restart and see if that got it.
i see you have some wdm drivers installed so that's an issue
windows 8...eeeeeew lol j/k
while you're at intels site pickup the newest RST driver too
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Software+Products&ProductLine=Chipset+Software&ProductProduct=Intel%C2%AE+Rapid+Storage+Technology+%28Intel%C2%AE+RST%29&ProdId=2101&LineId=1090&FamilyId=42
I think those are for windows 7 only, they both say I don't meet the minimum. I'm guessing I need the series 7 one
im not sure what you can do then.Windows 8* has a native in-box USB 3.0 driver. Intel is not releasing a specific Intel® USB 3.0 eXtensible Host Controller Driver for Windows 8.
If you are upgrading Windows 7* to Windows 8, uninstall the Intel USB 3.0 eXtensible Host Controller Driver before installing the upgrade.
Yea its likely dead... Anyway thanks a ton for the help + repOriginally Posted by Master__Shake
http://www.intel.com/support/chipsets/usb3/sb/CS-033977.htm
do you have a copy of windows 7 handy to see if it can be installed and if its working?
Yea it actually stopped working a real long time ago... I thought the front usb ports on my case had gone bad.......I wouldn't bother to RMA it over this anyway even if it was still in warranty.... I have usb3 on the back out the ass lol
