1 - 11 of 11 Posts
On max everyone says its quiet thats a lie its loud lol, also is a 1:1 divider pretty good, cause i need to do a ghz overclock in order to do it, or will i notice that big a speed difference?
It you hear the thing actually, you must have done something wrong. Mine is running full speed, and I don't hear it, even with the case open (three quiet case fans and a VF900 in addition to the 9500, and still pretty quiet.)<br />
<br />
1:1 is a recommended divider. Just set your RAM to DDR2 533 speeds, and then crank up your FSB>.
i cant hear mine either
These things are quiet and efficent? Maybe I should get one.
They're good coolers, but depends heavily on excellent airflow in the case. <br />
<br />
There are better coolers out there, like the big Nocture, the Scythe Infinity, the Tuniq Tower, and others, but these weigh a whole lot more than the Zalman.
<div>Originally Posted by <strong>Chozart</strong></div>
<div style="font-style:italic;">They're good coolers, but depends heavily on excellent airflow in the case.<br><br>
There are better coolers out there, like the big Nocture, the Scythe Infinity, the Tuniq Tower, and others, but these weigh a whole lot more than the Zalman.</div>
</td>
</tr></table></div>
How good does the Airflow need to be? 2 80mm extractor fans at the back of the case good enough?
<div>Originally Posted by <strong>MindOfChaos</strong></div>
<div style="font-style:italic;">How good does the Airflow need to be? 2 80mm extractor fans at the back of the case good enough?</div>
</td>
</tr></table></div>
<br>
Hmmmm... I would say 120 front and rear, that's what worked on my secondary rig. Do I hear a Case Mod on the horizon? <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
As a side-note: My CNPS9500 is audible at full, bit not "loud" - sorry I can't be more exact insofar as a dBa rating.<br><br>
Are you certain that the HSF is fully seated and not passing a very, very slight vibration?
Any intake fans? lol.<br><br>
Anyways if its loud then check to see if you bent or cracked/chipped any of the blades, that will increase the noise by a LOT. Other than that the 9500 isn't really a silent cooler by my standards but it should be quiet enough.
if you nave atleast a denent 80 in and out you should be fine<br><br>
i had 2 silent 120s and my 3700 stayed under 40 at full load 3.1ghz<br><br>
mine was very quiet on high<br><br>
maybe you got a defective fan??
Discussion Starter #11
Hmm thanks for the replys, it seems fine, my idle temps are like 42c but i got a ghz overclock and fan always on max, who knows ill pop on my sennheiser headphones and crank it up, problem solved lol <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> and i have an armor so airflow is good
1 - 11 of 11 Posts
