Just got my new equipment, need to change my sign. soon, anywhere, I was wondering to all who uses the zalman 9500, can I hook the 3 pin connector directly to the mobo instead of the controller first then mobo. I'm assuming it'll run at full speed constantly without the controller, is this correct, or does the controller make it run at higher speeds than if it were directly connected. Chances are, I will not be adjusting the controller for varies fan speeds. Any one have any ideas or suggestions?
