1 - 3 of 3 Posts
ok my Intel e6600, Asus P5B Mobo, and Zalman 9500LED arived also my AS5.<br><br>
Ok how should i apply the artic silver 5 to the cpu, do a rice size blob and let the heat sink pressure spread it, or spread if with my finger, or what?
put small grain in middle of IHS....small circular motion with HSF...attach and go!!!
That fan is a sod to install imo, very fiddly. What's more annoying is having to remove the motherboard to fit the damn thing. But with the temps it gives you it was well worth it.
1 - 3 of 3 Posts
