Zalman 9700LED, fan speed
3925 Views 11 Replies 6 Participants Last post by  ENTERPRISE
I got my Intel E6600 at 3.2GHz, and TAT reports 55-56 degrees Celcius under load, with Zalman fan at lowest speed. (Case fans are also all on lowest speeds).
If I turn the Zalman fan to maximum speed, there's no difference in temperature, or at most 1 degree... is this normal??
1 - 12 of 12 Posts
did you crank up the case fans also? Those Zalmans are pretty sensitive to case airflow. And what's your set up in that P180? I have front intake (120mm/35mm thick), top exhaust (120mm/25mm) and back exhaust (12mm/25mm). Also, I have removed the hard disk bracked in the upper chamber to improve air flow. My Quad Pack lives happily in the lower chamber.
Naw...
Besure that it's seated as snug as possible...my 9500 still wiggles a litlle on my AMD..but it's 25°C most days though
55-56C under TAT full load ain't too bad though...
TAT heats that thing up like nothing else I've seen
Case fans are stock, in their original positions (no front intake fan). I must admit, it felt a bit weird placing that Zalman almost right in between top and rear exhaust fans - seems to me that they do the work already, and the fan on the Zalman is superfluous (if I don't have a front intake fan...)
Front intake should definately help. Remove that hard disk bracket, (if any disks reside there, move them down), and install an intake fan. The Zalman simply does not get a fresh air supply, hence the lack of further drop in temps.
Yeah, thats like my Zalman, I notice a 1-2c drop idle and 3-4c drop Load, when I use the full fan speed setting. I dont have a front intake, I was thinking of picking up the Antec 900. Looks nice and cools nice by the sounds of it
Definitely add that front intake, not only for your CPUs sake but also for your graphics card(s) I noticed that Antec designed this case for systems built specifically to be silent so they weren't really banking on people using monster graphics cards in this case so they expected the dual exhausts to cause enough negative pressure to suck ample cool air through the front but it just isn't enough IMO, I added a SilenX Ixtrema I had lying around to the front and with it at 7v and all TriCools on "L" I noticed substantial temperature drops.
EDIT: Instead of mounting a 120 to the front of the case conventionally like I chose to, you can also leave the upper hard drive cage in place and use the included wire brackets to mount the 120 fan directly in front of your graphics card(s) that way the fan is closer to your CPU and would give it even better airflow, try it and see if it helps, I have the revision 2 P180B which has 3 25mm thick fans instead of 2 25mms and a 35mm so the wire bracket may not come with the revision 1, I'm not sure. If you can open the front door all the way until it touches the side of the case, you have a revision 1, revision 2s only open about 180-190 degrees.
This was the layout with my old rig (Opty 170). Right now, still similar, only that the bottom fan is gone
Thanks for the input, guys.
Remonster: I seem to have a revision 2, since the door does not open all the way, and I got the wire brackets :). Would seem like the way to go, since I have five drives - four in the bottom cage, and my boot drive in the top cage. However, the X1950XTX is quite large, not sure a fan will fit behind the drive cage. Perhaps it may fit in front of it - there seems to be a bracket there.
Chozart: Nice cable management there - now I must seriously reconsider my own - it's not nearly as neat. That must help airflow a lot too - I have an annoying flat IDE cable to the DVD, always been a cause of grief... Did you remove the top exhaust fan, or is it just not visible on the picture? It seems a bit overkill to have the two exhaust fans up there so close, when the Zalman fan sits just below the top one, and in front of the rear one.
How's the temp on your drives with the lower fan removed?
Anyway, it is definitely lack of airflow, since if open the side of the case, CPU temp drops 10 degrees C...
I have now reorganized the innards of my rig (all cables are now more neatly drawn), and moved the lower fan to the upper front intake. This resulted in a 5 degree (Celcius) drop of CPU idle temp, but my disk pack in the lower section now runs hot (46-51 degrees) - ouch!
I'm now thinking of moving the ceiling exhaust fan to the bottom section - there seems to be a surplus of fannage up top - still no difference between min and max Zalman fan speed...
Also thinking about lapping the Zalman and CPU for improved contact, but that's a later question :)
SpeedFan reports two other temperatures, System and AUX - anyone know which is what?
Also noticing that according to TAT, CPU 0 always runs hotter than CPU 1, up to as much as 5 degrees...
If you think about it, coolers like the Zalman 9700 must really operate optimally in an upright position, not on the side as when mounted in a tower case...?
System is usually the temp Probe monitor too look at in Speedfan however can sometime vary.
1 - 12 of 12 Posts
