I have a Zalman CNPS9500 CPU cooler and it ran fine up until now. Before at idle, regardless of the OC it idled at about 1600 - 1700 in speedfan. Now for some odd reason it is pegged at 2800 rpms all the time. I don't know whether it is because of the mobo or the fan. I reset bios to safe configuration and then bumped the FSB and took CPU voltage off auto and put it at 1.25v ; set memory timings and voltage and everything else is pretty much auto. Before this problem the settings where pretty much identical. The only changes to the computer was that I put in some 1000mhz memory from 800mhz. Any answers are much appreciated.
E8400 3.0ghz @ 3.5ghz 1.25v
GSkill DDR2 1000mhz
GA-EP45-UD3R
Antec Earthwatts 650w PSU
Seagate 160gb + 500gb
Zalman CNPS9500
GSkill DDR2 1000mhz
GA-EP45-UD3R
Zalman CNPS9500
