Title says it all; which one is the best cooler for a Nvidia 6800 AGP card? Note that the NV Silencer 5 I'm looking at is Rev 2, not Rev 3 ($10 cheaper and I don't see much difference in them). I'm leaning towards the NV Silencer because it eliminates the heat generated by the card directly outside the case, through a PCI slot opening.
Also, how would I take off the stock RAM sinks that came with the card if I wanted to install the NV silencer?
