1 - 7 of 7 Posts
Hello everyone ,just installed all bits in Zelman z11 plus works fine,waiting for couple extra fans,only one what can u stick at the top instead of that bit wich looks like little screen,betveen your usb ports at the top,what can go there,anyone aware,cheers??????
Hello there, as far as I know there's not a lot of things that can go there. The little piece is removable so I guess you could try some sort of DIY case mode and stick something in there. I just use it to put my phone on when I charge it via the front USB's.
1 - 7 of 7 Posts
