1 - 20 of 79 Posts
Retired Reviewer
Discussion Starter · #1 · (Edited)
Here is an oversize example of a ziptie screw:
Save all the zipties you clip. Pull the tongue out through the buckle. Now you have some spare buckles. The shaft of a ziptie runs straight through a fan or a fan+shroud, through your heatsink, and out the other side, where it meets one of your spare buckles. Now you can mount most fans to essentially any heatsink. A ziptie screw in action. A really classic use of ziptie screws:
Many thanks to Dirtyworks from this thread. Then go to this thread to really see zipties at work! And here:
Pic posted by ffejrxx. And flexible, too:
Posted by johny24 here.       Posted by reisya at post #57, this thread.   ------------------------------------------------------------------------   Here I needed to put a prototype 120x15mm Cooler Master fan on my Megahalems.   (A poem) None of my clips would do. I had to use a ziptie screw.
done it before
works great, i should have posted this... it was a light bulb moment for me(doesnt happen too often) so i was very excited about this when i first did it
Loosing Vision
IT's... It's... Educational!
Lol i been doing this for years my other pc has a ziptie hardrive cage i couldnt mount the orginal cages cause of the 2 fans i put in the front so i used zip ties and kinda made it float at the bottom of the case.
Originally Posted by GRPace View Post
This works great on heatsinks but watch out for vibrations if you try doing this on a a case. My friend has one of these on his case and it vibrates.
tip.... get bit of foam... or rubber lol...just a little bit... n put inbetween it ( put hole thru it for ziptie to go thru... )
or what i did..... bluetac
Retired Reviewer
Originally Posted by ehume View Post
I wonder how long people have been doing this?
No idea... I was just wondering the other day where the heck you could buy screws long enough to attach 3 or more fans on a cooler. wonder how long it will take for some company to make a tweaked version and sell them for this exact purpose
You best patent "Zip Tips" right now.
Do ziptie screws work on heatsinks that can hold three fans? I don't want to resort to buying another pair of fan clips for a third fan on some heatsinks.
Something like this seems like it would work. I have so many zipties I could play around with these all day
Retired Reviewer
Discussion Starter · #18 ·
Really now. A set of Megahalems clips that work fine on the D14 will cost you $4, shipped.
Look at item 4. in my sig.
I Am Gooble Gobble
if only i could utilize this to tie a fan + shroud to a rad...
I have a video on this too
1 - 20 of 79 Posts
