1 - 4 of 4 Posts
hello wel i wanted to overclock my videocard a little i already tried
750/1500/1900 woth stock volt of 1038 in afterburner
it works for the most part but at around playing starcraft 2 for 4 hours it mostly bsod's on me
can anybody give me some pointers on what volts settings temps i should try
and how far i can go on stock cooling
thanks in advance
With my ASUS card i was able to keep it at 840/1680/2100 @ 1.113, temps got a little high but not too crazy. That is with 100% fan.
thanks just found out my memory might be the devil and causing the unstable aspect so will try again later tonight when i got this demon under control
thanks in advance
Set the memory at 1000, set your core at 825, bump your voltage to say 1.113 or 1.125 if needed. Try to keep it as low as possible and crank the fan as needed as well.
I think your card should be able to do 875 core stable with that cooler and without needed so much voltage either. Memory overclock on these cards is crappy. Once you get a stable core overclock, play more with the memory overclock.
1 - 4 of 4 Posts
