2700K or 3770K? $40 difference
6.5K views 46 replies 30 participants last post by  Kaosuonline
#1 ·
Alrighty guys, I just bought the 2700K yesterday from NCIX becasue they had the 3770K at $385. But now they've lowered it back to $340. I haven't opened my 2700K yet so I can still get a full refund and pay $40 more for a 3770K.
I honestly can't decide which one. I bought the Z77 Sabertooth motherboard along with the 2700K if you're wondering.
EDIT: Decided on a 3770K
#2 ·
its up to you. anyways never go on PRErelease prices.
Anyways i would probably feel weird if my processor doesn't unlock my pcie 3.0 on my tip top board.
#4 ·
While the 2700k may overclock higher in sheer GHz, the 3770k will still beat it because of the improved IPC.
Go with the 3770k, I did.
#5 ·
I might do it if I was you, I've heard that the new Ivy Bridge line has increased the graphics by a bit and increased the overall performance by an insane margine. I would get the 3770k for 40$ more but thats just me, also great motherboard!
#8 ·
Well PCIE3 is still fairly pointless since at most we'll have is 2 GPU, and no way PCIE2 can bottleneck yet.
I can see that a Hyper212 evo kept the 3770K under 80c with 1.3v, So i think my RX360 can do a bit better, hence very tempting to go 3770K. One of the reason why I went with the 2700K is because of the lower temps.
Actually here in Canada, the prices are generally higher than what they are in the US. 2700K were all above $320 until this week.
#9 ·
Surely you've been hearing about how the 3770k is kept at reasonable temperatures until it reaches the 1.35-ish volt mark and then goes wildly hot to the point that no conventional cooling can bring it back to reasonable temps. Keeping that in mind that puts a cap on overclockibility such that it closes the gap between SB and IB. So IB may have better IPC performance, but cherry picked SB cpus like the 2700k will eventually end up performing the same when you OC them.
#10 ·
This is why I'm at a lost whether to spend $40 more on a 3770K. One can OC higher while the other have better IPC, costs a bit more, and it's the "newest and greatest"
#12 ·
Honestly I say stick with the 2700k. Even if IB turns out better than what the reviews so far make it out to be, the 2700k has got you covered for at least another 2 years. It's an excellent CPU and will overclock like a beast.
#13 ·
I'd go with that 2700K. The performance difference between the two will end up a wash. 5% faster IPC on the 3770K, and 5% higher clock on the 2700K. If you had some sick water loop or chilled setup you might consider the 3770K and not have to worry about the heat stopping you from getting those high clocks. If your just gunning on air, then you're looking at the same performance overclocked. If you need PCI-E 3.0, or USB3 or Lightpeak or any of that new garbage, then you might need the 3770K too.
Maybe you could get both of them, test them for a few weeks, and sell your least favorite.
#17 ·
That is not correct and I'm tired of people posting it as fact.
#20 ·
Theres no restocking fee since the 2700K is still sealed; and the fact that there's an NCIX from me within 10 minutes of driving, it wouldn't be an issue at all to exchange it.
And as PCIE2/PCIE3, theres only a small difference in performancce, just saying that PCIE2 is not bandwidth limited in any way.
#21 ·
I say go with 3770K, ok it heats more, but with a nice 25 oC room temperature, a case with airflow and a decent cpu cooler, you can get your (i say) more than 4.5Ghz with a voltage 1.3+ and still doesn't heat that much, you get other features, new chipset, PCI 3.0, and other stuff. And if you are lucky you can get it over 4.5ghz under 1.3v
#25 ·
I would go with the 3770K! Regular Sandy bridge will soon be discontinued as inventory goes down. No need to upgrade a system with old technology!
