A message to the community on enthusiast power supplies
7.1K views 33 replies 27 participants last post by  PapaSmurf
#1 ·
These enthusiast power supplies we all have (high-end Corsair, Antec, SeaSonic, Enermax, Silverstone, etc.) can take a lot more abuse than you think. I have tell people this a lot. These are heavy duty, precision engineered electron pushers, not tinker toys.
While you can't trust your average cheap or OEM power supply so much, and you can't trust a generic as far as you can throw it... A high-end enthusiast grade power supply is engineered with massive safety margins. Take the Corsair VX550. That's a CWT PSH, and Rocketfish/Best Buy took that same PSU (w/ minor modifications, nothing important) and rated it as a 700W and it can hold that rating within ATX specs.
When you buy a high-end PSU you aren't just buying reliability and performance, you're buying your headroom right there. Some people say, "Well the TX750 can push 900W, so when I buy it I'm getting a 900W PSU". That defeats the purpose. The purpose is that you can treat it as a 750W PSU and draw that amount from it long-term, for extended periods, while a cheap 750W might eventually break. That's part of the reason for buying a high-end PSU, instead of something just adequate, like an OCZ ModXStream or a Rosewill RV2 or a CM Silent Pro.
When you buy a high end enthusiast power supply, especially one that I can vouch for, you should know that you're buying into more than just a name. You're buying a machine, and one that's a lot tougher than the typical dreck you might have used before. So don't be afraid to use it for what it's intended for. Forget about "extra headroom", forget about babying your PSU or keeping some massive unnecessary safety margin. Go ahead, get that second Fermi and go wild. Most of you have already paid for that ability, so make the most of it.
#6 ·
Originally Posted by rocstar96;12194280
Nice read! All hail the PSU god.
^^ this
#7 ·
A good analogy I like to think of is two different cars, one a Ford Festiva and the other a Corvette. Cruising along the freeway at 80 MPH, the Festiva is trying as hard as it can but can do 80 when pushed. The Corvette might not even need to shift out of 3rd if it didn't want to. So running the Corvette and Festiva in their highest gear, the Corvette will be much less stressed and as such, will be more comfortable (better ripple, etc.) while also lasting longer since it is designed to actually handle at those speeds, not just reach it like the Festiva.
#9 ·
Again a great post my good sir. >.> When I get to, I am pulling 2 560s with my rig in the future
#10 ·
A good message as always.
#12 ·
Originally Posted by Lampen
For those of you who don't know Phaedrus heed his words! His articles, posts, and reviews were incredibly helpful when I was starting out here!
Yup Everything I know of PSU's is thanks to this great guy
I could still learn more
#15 ·
actually a corvette could do 80 in second gear comfortably. Just sayin.
1st tops 60mph, 2nd tops 85mph, 3rd tops 120mph.
source:
#17 ·
Getting real sick of seeing people trying to justify wasting money for "headroom" aswell.
And another thing, y'all need to stop treating Phaedrus like he's Jesus Christ. Sure he knows alot about PSU's and even I've learned a thing or two from him, however you should read his articles (and various others on the internet) to educate yourselves instead basing everything you say on "because Phaedrus said so".
#18 ·
Originally Posted by GameBoy
Getting real sick of seeing people trying to justify wasting money for "headroom".
But you have to consider upgrading. If you buy a quality unit that's "just enough" to get you by, and down the road you want to go Crossfire/SLI (or upgrade to Fermi!), then you are out of luck. I think it's nice to buy something with a little extra wattage than you need assuming pricing is okay.
#20 ·
It's funny when you see people recommending a PSU three times what someone needs "in case you go SLI" when their motherboard is single slot.
#23 ·
And remember, weight isn't all important. My Zalman weighs a ton, but is easily outperformed by lighter, cheaper and smaller units.
It's sexy though...all that silver
On that note, what would it be? Enthusiast? Mild-enthusiast lol?
The OCZ's aren't bad units, their just not high-tier like the AX/TPQ/X-series.
#24 ·
This, as I'm also tired of how people keep saying I would need a 1000W for GTX 580 SLI while I know I'll be safe with the AX850. Thanks Phaedrus2129
