Antec Dark Fleet Series Owners Club
43K views 228 replies 55 participants last post by  Inciter
#1 ·
#7 ·
Originally Posted by greg8west View Post
Style wise yes. Rest of it not at all. (I used to own a 932
Yep. It's a revision of the Antec 902/1200 trying to look like the HAF cases, you can't mix them up due to the size differences. HAF is much longer and wider. nitesoul, these are just as plasticy as the HAF cases but have thinner steel. Not being bulky isn't good functionally, less space for CPU coolers and side fans and less space behind the motherboard tray for cable management.
#8 ·
I have had not problems with coolers (v8, H50), and cable management was actually quite easy
#9 ·
The DF-85 is a good case, but much smaller than the HAF 932/HAF X. DF-85 is good if you have alot of 3.5" HDD and you aren't a fan enthusiast. One of the main values of DF-85 is that it has 7 fans out of the box, which is a great value if you don't add/replace fans on the HAF X/HAF 932.
You can see below how small the DF-85 is in comparison to the HAF X.
I still have my DF-85 but it is empty in my closet. My wife rejected it because she likes the HAF 932 better, so can I join the club?
#17 ·
http://www.overclock.net/overclock-n...l-threads.html
Just a note for this thread, since the club starter is still active. Once enough members are on board, contact one of the section editors for making it official; if they don't, then contact whomever they defer you to.
#22 ·
Originally Posted by pali;11913627
I have a df-85 with great specs. Will post pictures.
Anyone have a Zalman H70 cpu water cooler in theirs?
Sent from my DROIDX using Tapatalk
Do you mean Corsair H70? If so I have a H50 in mine:D
#25 ·
Originally Posted by Kvjavs;11942958
Anyone know if the DF-35 has any sort of cable management with the newer releases? When I bought my Antec 900, according to the stock image it had no cable management holes however it came with a few.
Here is part of a review where they talk about cable management.
