Hey guys,
I've been using my new rig for almost 1 month now. Since day one, I felt like the gaming performance should have been better and by better I mean, smoother (stutter free) and without huge FPS drops.
First problem:
The first game I tested was BF3, I was able to play it on Ultra 60+ FPS almost all the time and sometimes reaching 80 FPS. However, whenever there is some action (explosions and you know what Battlfield has to offer), the FPS drops significantly, sometimes 30- FPS, but this happens only for a second or two. So my first questions, is this normal ?
Second problem:
I know recording through fraps or mainly through any other problem will cause a significant FPS drop, but are we talking about 10-15 maybe 20 FPS or like in my case, 40+ FPS ? even though I have the game installed on and SSD and fraps is recording to an HDD. Note that this happens regardless which preset is selected (Low,Medium,High,Ultra,Auto). On the other hand, If I try to lock the FPS to certain number, lets say 60, the game becomes unplayable since the FPS drops happens quite often. My second question, is this normal?
Third problem:
Alright, the above two problems are manageable and can be ignored to a certain level. However, this problem is really giving me a hard time. The problem is that the game play (BF3) feels slow paced and sluggish, with lots of micro-stuttering when moving around. I've tried everything but still unable to overcome this problem. I've tried all the presets (from Ultra to low), but still, nothing have changed. On low settings, I am getting 100+ fps easily, reaching 170. But the micro-stuttering is still there.
To give you a better insight about what is really happening, I've uploaded a video on youtube, playing on an empty server:
http://youtu.be/Y8tmJy0ecGI
Note: I've recorded it using fraps locked @60fps, so the footage is twice as worse as in the game itself since youtube limit is 30fps.
I also did another test run:
Server: 64 players Caspian border
Run time: 13 minutes
Battlefield preset in-game: Lowest settings
V-Sync in-game: off
Adaptive V-sync: off
Nvidia Driver: 310.90 (I've already tested the 306.97 and 310.70, both same results)
CPU Clock: Default
GPU Log (MSI Afterburner) & CPU Log (HWINFO64): http://easy-upload.info/do.php?id=690
Fraps benchmark: (Original files: http://easy-upload.info/do.php?id=689)
I would really appreciate if anyone here can provide help on any of the above mentioned problem, thanks in advance.
First problem:
Second problem:
Third problem:
V-Sync in-game: off
CPU Clock: Default
