h70? what do u guys think?
I agree except for the 212+. For performance/price, definitely 212+. But for "best under $100", no freakin way. You also forgot to include Spire Thermax Eclipse. Why would OP think H-70 is the best? Doesn't even crack the top 20. And, last time I checked, it costs more than $100 (if you include tax and/or S&H).Originally Posted by That Guy;13638214
Silver Arrow
or
Noctua DH-14
or
CM 212+
or
ThermalTake Frio
Closed loop water cooling systems are a gimmick imho.
im not gonna lie, but that sounds awesome. 42c at load? not bad.Originally Posted by spilltray;13638448
Closed loop WC units do have a place though. With low RPM fans in a push/pull, I'm able to maintain 4.0ghz, just under 42C temps (load) and other than the gpu fan, my rig is virtually silent. Some people don't care about noise, but if you do, things like the Corsair Hydro series aren't junk at all.
Really? Because I wouldn't consider a pump a quiet device at all. But i haven't heard the Corsair Hydro series at all. My htpc/gaming computer only have 500rpm fans in it/passive heatsinks so i'm pretty sensitive to noise myself.Originally Posted by spilltray;13638448
from reviews i hear its super quiet. plus it depends on the fans you get.Originally Posted by systemlayers;13638465
Plus asus directCU cards aren't quiet imo
You would be able to maintain that OC w/around 37C temps (load) w/Thermaltake Frio. And the H50 uses a 120mm fan, just like many air coolers. Obviously, the noise level depends on what fan is used. People say it's junk because it is overpriced for the performance. The only pro I see is that it does save space.Originally Posted by spilltray;13638448
For ~the same price as an h70 you could get a rasa kit that would not only be silent but blow the h70 away by far.Originally Posted by spilltray;13638448
My ASUS Direct CU ENGTS450 it currently at 75% fan and I can barely hear it at all. And I am right next to my case.Originally Posted by systemlayers;13638465
