Bypass PSU Switch
1 reading
607 views 6 replies 3 participants last post by  OC Newbie
#1 ·
im fixing a HP for a friend, and when i try to switch it on nothing happens. so i tried another outlet and nothing.so i thought i would try a technique that i THINK im doing correctly by taking a piece of wire and connecting the green and black wire on the 20 pin connecter then plugging the outlet wire to the case and still nothing.A...am i doing it the right way,b.c there are more then one black wire?B if A is right does that mean he has a bad PSU?
#2 ·
Black is always ground so it doesn't matter which black you connect to and yes you're doing it right. Sounds like the PSU is dead.
#4 ·
what if the Mobo is grounded. would that keep the psu from coming on even if its being bypassed.. im thinking maybe it got shooked around or something.
If the motherboard is grounded elsewhere (aside from the PSU), you have a major problem since everything will short out. If this were the case, the PSU could blow completely killing other components as well.
Reactions: raycityclick
#7 ·
Originally Posted by crashagn
if uitrs a atx psu.. i beleive it would be the green and gray wire on the 20 pin mobo connecter that triggers the psu
I don't know where you heard that but with a power supply that adheres to the ATX standard (1.x and 2.x), you want to connect the green pin to any of the black (ground wires) to turn it on. raycityclick did it properly.
