SMA8 Review from JayzTwoCents
Probably the best looking case i have ever seen.
Tell me about it >_>Originally Posted by Ksireaper
After i watched this video, i am convinced. Nothing matches a Case Labs Case.
I just cant afford one.![]()
Got $800 saved for the new build so far and i'm having a hard time justifying the cost of this case.
UGH, so many decisions.
I have my entire build all planned out. All water cooling components picked. Only thing i cannot decide on is the case. Should i take the hit and buy the SMA8 and set me back a bunch, or just go with the 750D like i planned?
What is your new planned build?Originally Posted by Ksireaper
Same thing with my current build, took forever to choose a Case.
Edit: Punctuation
Going with Haswell-E i7 and an EVGA board when they come (if they are out when i am ready) as i have always had good Luck with them.
There are several case manufacturers in the water cooling game now. Corsair is one of many - which is great for the consumer, there are more choices than ever
Yup. But the problem is this. When i see a CaseLabs case, then switch over to looking at a Corsair case, to me it is the difference between Bugatti and Ford. Case labs is so far ahead of the game it is not funny. I am thinking about picking up either a Mercury S8 if i can figure out the best way to hide the wires on 2, 360 rads in push pull in the ceiling. The other choice is the SMA8, which just might be a little out of my budget.
The kind words are appreciated.Originally Posted by Ksireaper
That's probably less than what the raw materials for each case cost, so, not likely unless our economy grows through the roof.
Come on man, CL makes amazing cases but its not magic or anything. If they made a $50 case it would have all the compromises and issues of any other $50 case out there. The reason CL cases can be so awesome is because they don't have to worry about hitting a price point and can use the best of everything. I'd have a CL case right now if they could make a 90 degree rotated mobo tray as that is the one feature I simply can't do without after having bought my also amazing TJ11!
Buy us the patent on the 90 degree orientation and you can have one.Originally Posted by Majin SSJ Eric
Come on man, CL makes amazing cases but its not magic or anything. If they made a $50 case it would have all the compromises and issues of any other $50 case out there. The reason CL cases can be so awesome is because they don't have to worry about hitting a price point and can use the best of everything. I'd have a CL case right now if they could make a 90 degree rotated mobo tray as that is the one feature I simply can't do without after having bought my also amazing TJ11!![]()
