This is a brand new build; only been running for a couple of days. My problem started with a BSOD regarding 'Memory Management'. I've run Memtest under several configurations; testing each stick individually in the same slot, in pairs for each dual channel, and all four at once. For the individual sticks, I only had one fail, and on reinserting it, it passed. Dual channel configurations passed every time. However, when all 4 sticks are placed, I get a massive number of errors, usually starting between tests 3 & 5. Also, the system defaults the RAM to 1333Mhz, and if I try to bump it to 1600 (fully loaded), the PC refuses to start up. If I have only two sticks, it works fine. I haven't messed around with the CPU settings.
Here is my current build (keep in mind, I'm a newb at OC'ing).
Mobo: ASUS Maximus IV Extreme
CPU: Intel i7-2600k
Cooling: Corsair H70 (w/Cooler Master Excalibur fans x2), 200mm x3, 120mm x1
Memory: Corsair Vengeance 16gb 1600 (4x4gb)
Power: Cooler Master 850w Silent Pro
Graphics: EVGA GTX570 x16
OS: Windows 7 Pro
The Mobo BIOS were updated straight from the CD that it came with, so I'm not sure if updating them from the web would correct the issue. So far, I'm not convinced that it's an issue with the RAM. My biggest fear is an error with the Mobo hardware itself. Assuming it's not an update issue, what else could it be? How can I check?
CPU: Intel i7-2600k
OS: Windows 7 Pro
