D-link DWA-556 PCI Express Xtreme Desktop Adapter
Description:
D-Link helps remove clutter from your life. Okay, so it's just cable clutter -- but anything helps. The DWA-556 Draft N wireless adapter can achieve transfer speeds 3x faster than wired fast ethernet without ugly wires tangled up behind your computer. It's also up to 14x faster and has a 6x longer range than 802.11g networks. The high speed PCI-e interface lets you take maximum advantage of the adapter. Installation of this PCI-e card is fast and easy with the Quick Adapter Setup Wizard that takes you through the process step by step. Once the adapter is set up you can surf the web, stream HD video and transfer files, all at the same time. Because the need for security is at an all time high you have a choice between WEP, WPA and WPA2 protocols to protect your data. In addition to data protection a secure network means that nobody is leeching bandwidth and slowing your network down. Standards: IEEE 802.11g/n Security: Wi-Fi Protected Access (WPA, WPA2) WPA/WPA2: WPA2 Frequency Band: 2.4GHz - 2.4835GHz LEDs: Activity Antenna: External Antenna Dimensions: 4.7" x 2.7" x 0.1" Weight: 0.31 lbs.
Description:
