Ethernet card compatibility issue with vista, HELP!
570 views 15 replies 4 participants last post by  CaNe
#1 ·
I'm attempting to upgrade to Windows Vista Home Premium, apone thinking of doing such a thing i ran the windows vista advisor like a smart little boy that i am, it came back telling me my computer is just fine for running it.
Only thing my system seems to have a problem with are both my internet connection cards, 1 is my wireless USB card, and the other is a PCI card.
Wireless card name: 2Wire 802.11g USB Wireless LAN Card
PCI card name: Linksys LNE100Tx Version 2.0 Fast Ethernet PCI Card
Now i'm wondering are there any drivers out there that can make ether 1 of these be supported by windows vista home premium? or am i basically screwed for connecting to the internet until i get a new ethernet card?
#2 ·
now i just did another search just now, and came up with this but im not 100% certin this is the right drivers for me, this image looks close to what i have but its not 100% te same wireless USB card.
http://www.2wire.com/index.php?p=331
Anyone able to tell me if that will work for me?
#8 ·
Originally Posted by ENTERPRISE
To be honest with you even though the hardware may look like a different model the drivers can sometimes be very generic and you may find it would work fine for you. At the end of the day if they dont you can roll back the driver.
Well the thing is, you cant roll back from Vista to XP can you? because once i upgrade from XP to Vista via CD then ill have too install these new drivers for my wireless 2wire USB card and once i do that and it still doesent work then how am i suppost to get internet right... i maybe wrong about rolling back to XP but its something im looking into if i need too do it.
#10 ·
No I meant roll back the driver.
Also no...Once you login succesfully once after setup you may not Roll back to XP.
#11 ·
Originally Posted by SpuddGunn
If you can find drivers for it for Win 2003, then use them
I had a similar issue and was advised to use those drivers.
Well i went to there website and the only drivers they list are here.
my adapter is the very first one.
#12 ·
So theres absolutely NO way in hell i can roll back to XP, in other words ill have to backup all my files and programs and reformat
#14 ·
I am afraid you are correct !.
Well thats just JUNK!!! lol, damn windows microsoft, why cant things be so easy in life? oooh wait i know.. Cause its LIFE!!! lol
well thanks ENTERPRISE ill be sure to
again to get more info from you
