Friend's GTX 470 Hits 100!
1.8K views 15 replies 13 participants last post by  AyeYo
#1 ·
My friend has GPU Meter running on his desktop. When playing a game we noticed the fan on his card flared for a second. He minimized his game and it said the temperature was 100 degrees! It goes down quickly but that's bad, considering the max temperature for that card is 105. What should he do?
#2 ·
Aftermarket cooler!
#3 ·
does he have the card overclocked,, how fast was the fan spinning on the card? it wont do damage if it wasnt that hat for long like if you ran it for an hour at those temps then you may have sojme damage!
#12 ·
He did crank the fan speed to 80% manually and it's holding in the 60s.
Was it set at 80% when it over heated? MSI Afterburner is good for setting fan profiles which will allow the fan to spin at 100% speed if needed.
GTX470 is an awesome card but it gets very hot. Best cooling I can think of for it is water cooling. that is what I did with mine. If water cooling isn't an option then look at getting good aftermarket heat sink that can get the temps down.
