High CFM fans
1.5K views 29 replies 10 participants last post by  Triplesec
#1 ·
#2 ·
Those are good choices and probably the best you are going to get for a reasonable price.
Reactions: GeforceGTS
#8 ·
Undervolt = less CFM. Kinda defeats the purpose of buying a high CFM fan.
Anyway seems that the site I was going to buy the Scythe fans from doesn't take maestro ;[ So I might end up having to get a couple of these maybe
http://www.scan.co.uk/Products/Produ...oductID=656147
Almost the same CFM but slightly louder ;l
Unless I find somewhere else that sells the Scythes and accepts maestro..
Oh and anyone know where I can get a bolt thru kit in the uk? ;]
#11 ·
How many you going to get - as each of those silverstone fans needs a 3.5" mount for the controller
Have a look at the internationaly shipping stores like i think newegg?
The scythe fans will do you good - and if you turn them down they are brilliant - the 2000RPM kaze is very quiet up to about 75% speed, then it becomes noticeable in my system - have them turned right down when not gaming/benching,
#13 ·
I'm perfectly happy with my coolink fans ... maybe a bit less CFM but at that noise level, you can simply put in twice the fans! My system has 7 fans integrated (on watercooling) and you simply can't hear them at all (all on very low voltage off course). High RPM isn't always the solution ... good airflow is
#17 ·
Yes - and if i turn on the 2 GFX cards to 100% - you can here it at the bottom of the stairs at our place [about 10m to the top of the stair from room door]
Picture: Obviously my TRUE isn't mounted - the Kaze goes on the HDD side of it - that is the slipstream at the back:
Count them: 9 there, 2 you cannot see in the picture [one infront of HDD's and front intake] and another 2 added after the picture [2x 40mm for the northbridge]
#23 ·
Originally Posted by GeforceGTS
I never thought of mounting a 80mm like that, it is a 80mm blowing over your ram?.. I have one attached to the top of my middle HD rack, with tie clips ;D angled blowing on my 8800. Do those PCI slot fans actualy move much air?
Yeah - it's blowing over my ram - did have 2 80mm fans cabletied together for my ram but it dosent fit well with my new board:
Pictures of that:
This one does - but not where i wanted it to go - i wanted it to go next to my northbridge, but the small gap between the card and the top gfx card made them move very little air at all as it couldnt get much air because of the small space between cards - where they are it moves about the same if not more air than my slipstream [110cfm+]
I also have that 92mm fan in my hdd rack for the lower part of the ram and northbridge a bit to.
#26 ·
Have you checkout Zalmans ZM-F3, I don´t think you can get any cheaper with that performance.
http://www.scan.co.uk/Products/Produ...oductID=396304
And as Vapor at Xtremesystems wrote
Zalman ZM-F3 - The shocker of the whole group. Really, it came out of left-field. No fluke here either, Cathar got nearly identical results. No extraneous noise, magic-scaling above ~1600RPM, does well on a radiator, a mere $10 and available nearly everywhere and just overall great performance. A gem of a fan in many respects. It is a sleeve bearing though, it's only detractor.
Zalman ZM-F3 - The surprise of the bunch catches up to the San Ace on the radiator, but overall it's still not quite as good....though definitely an awesome, awesome fan.
I have 6 in a push pull for my radiator at 5 volt and it´s really quiet and if I go 7 volt they are still quiet, I really recommed these.
