So I got a reference 7970 that i love to bits performance wise but the noise is driving me up the wall!! I decided water cooling the thing would help plus the generally lower temps is another bonus which might improve my overclocking headroom. Waterblocks are super scarce in South Africa where I live and importing makes the already expensive blocks even more expensive. So I decided to put my thermodynamics knowledge to the test and design my own water block. I have a friend at varsity in engineering that has access to a 5 axis mill so he can cut the final design for me. My problem is that I need the card in my pc to design the block so I don not want to continuallu remove and replace the cooler until the design is finished. I need a few measurements on the card and was hoping if anyone could help either if they are willing to remove their cooler or if they are in the process of replacing a cooler or if someone has a waterblock at hand. Firstly I need to know the relative heights of the GPU, RAM and VRM's since I need my block to touch all of these.
The image above should explain what I mean: I need the block tou touch all the marked components and it's easy enough to calibrate the image to get the x and y sizes of all the components but I need heights. Can someone please measure (ideally with reference to PCB height) the height of the RAM chips, the GPU and the VRM's? Also of importance will be the height of the components that are higher than the highest of the afore mentioned three, specifically the capacitors next to the VRM's. Please please please, this information is very important. Any help will be great.
