i7 2600k not running at 4.6 ghz....
2.1K views 27 replies 10 participants last post by  Cer[v]3r
#1 ·
I overclocked my cpu to 4.6 with turbo on...
I stress the cpu with Prime95 and it only goes from 1.6ghz to 3.5ghz...
Why doesn't it jump to 4.6ghz?
I'm using Corsair H60 with 52C on load.
#3 ·
I believe it has to do with how Turbo works but im not positive. Try disabling Turbo and OC with the CPU multiplier then try. Thats how my OC is setup
#6 ·
If you disable turbo you can't OC these I thought. Since it's a ratio above stock it has to be done via the turbo function. (I may be wrong, I often am
#9 ·
Sure you can, you just adjust the CPU multiplier rather than the Turbo's. I just disable Turbo and do the CPU. IE im @ 4.4GHz so I type 44 for the CPU multi. 44x100=4400
#11 ·
Originally Posted by Cer[v]3r
I want to keep turbo on but why does it only say 3.5ghz with prime95?
From what I have read, it depends on the load across cores as to how much Turbo kicks in on a core. I don't know for sure but I just want a consistent OC so I canned Turbo lol
#13 ·
Originally Posted by imagine2112x
for one, it depends on how many cores are in use, so when prime 95 uses all of them it wont go to 4.5ghz. try superpi.
secondly, when it does go to its maximum turbo frequency its often for less than a second so your read wont catch it.
The turbo on Sandybridge works all the time unlike AMD or previous Intel. Here is how Turbo works for the 2600K:
38x With 1 Core in Use
37x With 2 Cores in Use
36x With 3 Cores in Use
35x With 4 Cores in Use
If you set a manual turbo multiplier in the bios to say 46x... It becomes this:
46x With 1 Core in Use
46x With 2 Cores in Use
46x With 3 Cores in Use
46x With 4 Cores in Use
It overrides all of the stock turbo multipliers with 46 as a fixed one. This is how overclocking was intended on Sandybridge.
By default, no matter what you're doing besides idling Turbo will be in effect and at stock will run at 3.5GHz. Normally if you set the Turbo Ratio in bios to a fixed value it overrides all of the turbo multipliers for everything so regardless of how many cores are in use you get that fixed multiplier rather than a set one depending on each core.
#16 ·
so there is no way for it to jump straight to turbo when i need it?
There is, you can set manual turbo ratios depending on how many cores are in use or you can set a fixed turbo multiplier that applies regardless of how many cores in use.
Originally Posted by KrisBKreeme
Turn the turbo off.
And.. once again someone who knows nothing of Sandybridge.
#17 ·
I think your best bet if you don't want your CPU running @ 4.6GHz until you go under load, and don't want to fiddle with Turbo, Turn Turbo off, set your CPU multiplier to 46, and leave EIST on
#19 ·
I agree.
You do not want your cpu running at a constant 4.6 ghz even at idle it is a waste of power which produces more heat.
The turbo kicks in instantly when it is needed and all cores will run at the same speed if you set each individual core to 46 or the same. Goto manual tuning and adjust all 4 cores to 46
#22 ·
I followed this:
4.6Ghz Settings - 1.000v idle - 30 degrees/ 1.3v Max Load - 70 degrees max (3 weeks stable)
AI Overclock Tuner: Manual
BLCK Freq: 100.00
Turbo Ratio: Enabled (All Cores)
By All Cores: 46
Internal PLL OverVoltage: Enabled
Mem Freq: (AS PER YOUR RAM)
EPU Power Saving: Disabled
Load-Line Calibration: Regular
VRM Freq: Manual Set to 350
Phase Control: Extreme
Duty Contorl: Extreme
CPU Current Capability: 100%
CPU OverVoltage: Offset Mode
CPU Offset: + 0.070
DRAM Voltage: (AS PER YOUR RAM)
VCCSA Voltage: Auto
VCCIO Voltage: Auto
CPU PLL Voltage: Auto
PCH Voltage: Auto
CPU Spread Spectrum: Disabled
CPU Ratio: Auto
Intel Adaptive Thermal Monitor: Enabled
Intel Virtualization: Disabled
Intel SpeedStep: Enabled
Turbo Mode: Enabled
CPU C1E, C3, C6: Enabled
Still only goes to 3.4
I also tried the setting so cores cannot change in OS
