Hey guys. Sorry if I've done anything wrong, I'm new here. I was looking for some kind of assistance with a low FPS problem I've been facing with this card. I by no means get 'unplayable' FPS although I definitely don't have the performance I deserve for the $300 I paid. I'll list one example that you may possibly be able to assist with. Today I bought Saints Row the Third, expecting an average FPS of 50-60 on ultra settings, as people have achieved all over youtube with this card. However, I average around 40-45, low being 30 and high being around 70 (rarely). I was lead to believe that this may be a CPU bottleneck as when I turn the setting down to low, I can still not maintain 60FPS at all; and I also have a fairly cheap processor (i3-2120 @ 3.30Ghz). However I ran task manager on my second monitor whilst playing and not a single core was at 100%. My overall/ average GPU usage (as monitored by Radeon Pro) was around 70%, never exceeding 85%. So this rules out a GPU bottleneck. My ram usage was around 50% so this rules out a RAM bottleneck. What else could it be?
A VERY important point is that I am using a SEPARATE power supply for my GPU (a generic 450w power supply, which does NOT have the sufficient amps for the card) although I've used this power supply for a while and had no problems (although when I push the powertune/clock setting up, my display crashes and a hard reset is required). I am using this PSU as I have yet to buy a new one, and I figured that because it is dedicated to the GPU and is not sharing any power with any other components, it should suffice - am I very wrong? I also LOCKED the GPU core at 1000mhz and monitored it during gameplay, it did NOT leave this clock speed. Also, temps are in the normal range.. 50-60 or so degrees. Any ideas? Thank you !!
MY SPECS:
i3-2120 @ 3.30ghz
6GB Ram (2.99 usable due to 32 bit operating system - getting 64 bit soon)
Powercolor HD7950
1x2 TB HDD
1x1 TB HDD
500w generic PSU powering all components of PC apart from GPU which is powered by a 450w generic PSU.
Windows Ultimate 32 bit
I will include a pic of my CPU and RAM usage as screen captured while my FPS was at 45. (the average fps i experience
MY SPECS:
i3-2120 @ 3.30ghz
Powercolor HD7950
1x2 TB HDD
1x1 TB HDD
