Micro ATx in ATX case?
517 views 9 replies 4 participants last post by  fstfrddy
#1 ·
can i fit a Micro ATX motherboard in a ATX case? will everything line up in my big case or should i try and find a full size ATX motherboard
#2 ·
In most full size cases this will work, as micro ATX is used so they can fit in smaller cases. Most mid-towers and full-towers accept both micro-atx and atx or extended atx. Usually it is the small cases that use micro atx because they cannot fit regular ATX, so you should be fine. I know my full-tower can. If you are really worried check the manual/ website.
#4 ·
alright good.. i think im going to buy a 50 dollar ASus board or Gigabyte.. i dont know yet.. whats a good board for a P4 northwood 533 Fsb... under 100 bucks? i Need HT technology and up to or more than 2 gb of DDR 400
