So since liquid helium is the coldest coolant there is I thought what if you could recycle the Helium so it wouldn't have to go through K tanks left and right.
So I found the parts to make the most awesome phase change unit ever.
Using 5 PT415 Pulse tube Cryorefridgerators to re-liquify the helium. http://www.cryomech.com/PT415.php
and A regular LN2 evaporator tube cooler
Sounds over kill but imagine -230C as a max temp
And it only uses 53kW of power.
