raid0 & vista 64-bit
349 views 2 replies 2 participants last post by  kamran5461
#1 ·
i recently setup raid0 and re-installed vista on it and most of the updates were succuessfully installed but these ones keep getting an error. it fails about 75% into the installation process.
before i had raid0, all my updates would install at 1st try. any ideas?
#2 ·
what failed? It most likely isn't a RAID issue as long as you have an updated RAID driver. It is probably something else.
#3 ·
the bunch of updates you see in my screenshots ? they all fail to install. so as a test, i installed vista 32 bit to see if the updates might fail, they didn't.
they all installed successfully. how about that huh.
