RAM Latency
1.5K views 11 replies 6 participants last post by  CL3P20
#1 ·
Hypothedically, lets say I have 4 gb. It is 9-9-9 @ 1600mhz. I replace the 4 gb kit with new 8 gb kit that has the same specs, 9-9-9 @ 1600mhz. Any reason to believe that replacing the 4 gb kit with the 8 gb kit would add latency to the computer and be slower?
#2 ·
No, but there are far more timings than just the 3 you listed.
#4 ·
I understand. I was just stating a hypothetical.
I was told a long time ago, that having to much ram that wasn't actually being used will hurt the systems over all performance and add latency. So is this not true at all?
#6 ·
Adding more dimms can raise the latency though. 2 packs of dual channel ram don't always have the same timings as a single pack.
#7 ·
No, your computer doesn't care where the memory address is physically located and can access date on stick #3 just as fast as it can on stock #1. In the past, 4 sticks used to put a lot of strain on integrated memory controllers and I believe that's where the rumor started. I remember most IMCs didn't like running a 1T command rate with 4 sticks.
#9 ·
Mhz.
Timings are nice, but the frequency speeds make a bigger difference since it'll lead to faster data transfer speeds. It's not worth going from 9-9-9-24 timings to 8-8-8-24/7-8-7-24 timings for example. Some of the 4GB 2133mhz kits from G.Skill are kinda cheap as well.
Remember, a better GPU/GPU will still have the biggest lead in terms of gaming performance over RAM, but needless to say, it can be very handy in synthetic and workstation-based tasks.
Here are some benchmarks.
From Kitguru:
From Legitreviews:
Hope this helps
#10 ·
Sounds like what you are referring to is the stress put on the IMC.
You will limit the stable latency and speed range/potential of your IMC/NB by increasing the amount of memory.
ie- 4GB's of ddr3 at "x" speed and "x" timings...
increasing to 8GB's of the same RAM.. you would be very lucky to ever reproduce the same speed/timings.. just due to the IMC now addressing 2x the amount. This is also why, anyone with +12GB's of RAM will hardly ever be able to run an OC on them. <- Its not for the poor Q of the RAM.. but rather the stress on the IMC is too great with that amount, to cut latency.
**Also- most games will benefit from a higher mem speed rather than lower latency.. but for all other daily tasks.. the lower latency will make for a more responsive system with less wait time!
