Reputable Registry Cleaner/fixer?
1.1K views 11 replies 8 participants last post by  TwoCables
#1 ·
Looking for some feedback on a reputable registry cleaner, so far I have discovered CCLeaner and Glary Registry repair.
Anyone have a positive experience with these programs without any unstable drawbacks?
My OS is Windows Vista
I've heard that cleaning/fixing registry helps boost computer performance, is this true?
#2 ·
CCleaner is the only one that is really trustworthy. The rest are pretty much a scam. Don't rely on utilities to make your computer magically much faster... That comes with hardware upgrades
#3 ·
It's mostly a myth/placebo effect. Worse than that, "cleaning" the Registry has a history of breaking things inside of Windows (sometimes the entire OS itself).
So, not only is it a waste of time due to the risk of having problems, but it doesn't actually make a real-world difference. It's like taking a 1 million word document and removing just a couple hundred words to make it open faster; it just won't make a difference.
In other words: I recommend that you avoid "cleaning" or "repairing" the Registry because sometimes it'll find false positives and then you'll be screwed.
#5 ·
Take this advice. Don't use them. I've used them for years thinking they have been doing some good. Over time it causes some really bad issues.
#6 ·
Yeah.... the registry is like an .ini file. The OS/apps uses to store lookup values. Removing some won't do much.
#7 ·
Only use CC CLeaner or any other registry cleaner if you know what you are doing/looking at. If not you have the possiblity of doing more harm to your computer than good.
I do use CC Cleaner to throughly remove any traces of vid card drivers whenever I install new drivers or if i upgrade my vid card.
#8 ·
CCleaner will backup any reg entries you delete in case it screws something up. I only use it after uninstalling something in case it leave entries behind that conflict with a future install.
CCleaner also will clean cookies and internet cache, also Add/Remove program and disk clean/defrag
Even if you don't use the reg clean tool it is a good piece of software.
#11 ·
Originally Posted by CryJunky
Ccleaner is a great program. I've never had a problem with it. Whenever my computer starts to slow down I run it with a defrag. It's part of my flash drive tool kit when I work on my friends computers.
Defrag does not really help much for "computer starts to slow down".
#12 ·
I'm not saying that CCleaner is bad. I'm just saying that it's not worth using it (or anything) to "clean" or "repair" the Registry unless you are absolutely, positively, 100% sure that there are no false positives - but even then I still recommend avoiding it. I've never seen any proof that "cleaning" or "repairing" the Registry provides a real-world performance/stability improvement.
Now don't get me wrong: if the Registry really needs to be repaired and if you know what needs to be repaired, and if you can recognize every single real false positive, then go for it - especially if you seem to have no alternative.
