Which will be faster; 2 7200RPM HDD's in RAID 0, or a 10,000RPM HDD. Anyone have a link to solid proof, or just guessing?
Faster? All Raid will help is large sequential reads/writes like transferring massive video files around. If you're expecting improved access times or your games to load faster then you're kidding yourself. With that said, I'd much rather have the fastest 10krpm drive over the fastest 7200 rpm drives in Raid.Originally Posted by michinmuri;11900863
Probably gonna go here. I am more about gaming than transferring huge files. Just to be a weirdo (and if I can not break my bank) I will RAID 0 two V-raptors, maybe 3?Originally Posted by sccr64472;11909211
data is never technically lost forever. to loose it forever, youd have to replace it.Originally Posted by ShadowOfDeath;11925423
The 10000 RPM drive is more reliable
As if you have 2 hardrive in a array, and one of them fails all you're data is lost forever
***?Originally Posted by GlockZoR IV;11925467
I understand this and am ok with that outcome. The risk is worth the reward.Originally Posted by ShadowOfDeath;11925423
As long long as that is the case then I am going here. Never thought of even looking due to price.Originally Posted by asuindasun;11925442
Why don't you just get an ssd instead? Costs about the same as 10K drives last time I checked... Just grab the crucial C300 128gb or vertex2 120gb and call it a day![]()
I can not fill one 320GB HDD so why 3 of these, lol?Originally Posted by microman;11925446
maybe 3 of these http://www.newegg.com/Product/Product.aspx?Item=N82E16822136762&cm_re=raptor-_-22-136-762-_-Product although i doubt the rest of your system could keep up
Originally Posted by ShadowOfDeath ![]() The 10000 RPM drive is more reliable As if you have 2 hardrive in a array, and one of them fails all you're data is lost forever |
I've never agreed with this sentiment, simply because I don't understand it. Surely since the drives are independent, the chance of array failure in RAID 0 is exactly equal to the chance of any single drive in the array failing?Originally Posted by Riou;12015842
And RAID0 2 drives does double the chance of data loss. If you disagree with this fact, learn statistics and probability.
Originally Posted by DuckieHo ![]() No. It's not a myth... it simple statistics. HDDs still do fail today. The risk increase is near linear for each additional drive. Correct. The probability of any individual drive failing is no greater. However, since the failure of any one HDD in array means failure of the entire array, the probability of the array failure is higher. Please understand what MTBF actually represents. A MTBF absolutely does not mean the average useful life of the drive will be 22 years. www.apcmedia.com/salestools/VAVR-5WGTSB_R0_EN.pdf The risk of RAID failure is (assuming you are using the same drives): P = 1 - (1-F)^n where P = probablity of array failure F = single drive's failure rate n = number of drives If you had HDD with a 3.00% yearly failure rate, then the yearly failure rate of a 3xRAID0 would be 8.73%. |
